Aller au contenu principal
LG VX6000 Body Replacement
Ce dont vous avez besoin
  1. LG VX6000 Body Replacement, Battery: étape 1, image 1 de 1
    • Locate the dark gray tab on the back of the phone towards the top. Push the tab towards the top of the phone to release the battery.
  2. LG VX6000 Body Replacement: étape 2, image 1 de 1
    • Remove the battery by lifting up and rotating the battery away from the bottom edge.
  3. LG VX6000 Body Replacement, Body: étape 3, image 1 de 1
    • Pull out the two rubber cushions located on the top of the phone using tweezers.
    • Only remove the two cushions that are circled!
  4. LG VX6000 Body Replacement: étape 4, image 1 de 1
    • Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
    • Remove screws and carefully place on an uncluttered surface or in a small container.
  5. LG VX6000 Body Replacement: étape 5, image 1 de 1
    • Carefully remove the back of the phone gently using your fingernails or tweezers.
    • There are a pair of red and blue wires that plugs into the motherboard. These wires will snap if you force the pieces apart.
    • To reattach the back, you must plug these wires back in.
Ligne d'arrivée
Barrett Wallace
Membre depuis le 01/18/10
1 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 4-11, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 4-11, Forte Winter 2010
CPSU-FORTE-W10S4G11
5 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 2,106
