Introduction
The front keypad suffers a lot of wear-and-tear, but can be easily replaced. This guide will show you how to remove the old keypad so that you may install a new one.
Pièces
Aucune pièce nécessaire.
Remove the two triangular pads at the top of the two speakers.
  • Remove the two triangular pads at the top of the two speakers.
  • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
Ajouter un commentaire
Remove the two rubber cylinders from their shafts. These cover more screws.
  • Remove the two rubber cylinders from their shafts. These cover more screws.
  • This requires a little more effort, so you may need to "dig" them out.
Now remove the four screws.
  • Now remove the four screws.
  • The screws are small, so put them somewhere that you can easily keep track of them.
Starting on the side with blue square, pry the faceplate upwards with the flat end of a spudger.
  • Starting on the side with blue square, pry the faceplate upwards with the flat end of a spudger.
    • Continue to slide the flat edge along the seam of the faceplate.
  • You should hear popping or snapping noises as the faceplate is being removed.
The faceplate is attached by wires, so do not pull the faceplate very far away from the phone. The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
  • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
The faceplate is still attached through speakers that travel from the ear-piece to the motherboard. Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate. This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
  • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
  • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
  • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
The faceplate and keypad can now be completely removed from the phone.
  • The faceplate and keypad can now be completely removed from the phone.
Ligne d'arrivée
Aaron Rowley
Membre depuis le 21/01/2010
33 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 16-32, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 16-32, Maness Winter 2010
CPSU-MANESS-W10S16G32
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,831
