Turn over the phone so the front screen is facing down and the back side is up.
  • Turn over the phone so the front screen is facing down and the back side is up.
Ajouter un commentaire
Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
  • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
  • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
  • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
  • Then press down on the bottom of the battery and it should snap into place
Michelle
Membre depuis le 10/04/2012
17 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 17-26, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 259
