If your LG Voyager camera is not working properly, you can replace it by following the steps in this guide.
Unscrew all four screws from the corners of the back cover.
Using a plastic opening tool, gently remove the back cover.
Gently press the replacement camera into the old one's place.
Replace all of the phone's removed parts, and you are ready to use your new camera.
Intégrer ce tutoriel
Choisissez une taille et copiez le code ci-dessous pour intégrer ce tutoriel sous la forme d'un petit widget sur votre site / forum.
Aperçu
