Aller au contenu principal
LG Voyager Keyboard Replacement
Ce dont vous avez besoin
  1. LG Voyager Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Turn over the phone so the front screen is facing down and the back side is up.
  2. LG Voyager Keyboard Replacement: étape 2, image 1 de 1
    • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
  3. LG Voyager Keyboard Replacement: étape 3, image 1 de 1
    • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
    • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
    • Then press down on the bottom of the battery and it should snap into place
  4. LG Voyager Keyboard Replacement, Keyboard: étape 4, image 1 de 2 LG Voyager Keyboard Replacement, Keyboard: étape 4, image 2 de 2
    • First remove the rubber stoppers covering the screws on the back of the phone by prying them up and away from the phone.
  5. LG Voyager Keyboard Replacement: étape 5, image 1 de 2 LG Voyager Keyboard Replacement: étape 5, image 2 de 2
    • Remove the 3.61mm length, Phillips screws from the back of the phone using the #00 screwdriver.
  6. LG Voyager Keyboard Replacement: étape 6, image 1 de 2 LG Voyager Keyboard Replacement: étape 6, image 2 de 2
    • Now pry open the back of the phone.
    • Make sure that you use the plastic opening tool to go around the entire phone to help open the phone.
  7. LG Voyager Keyboard Replacement: étape 7, image 1 de 2 LG Voyager Keyboard Replacement: étape 7, image 2 de 2
    • Carefully separate the keyboard from the top of the phone.
    • Be careful not to break the ribbon cable.
  8. LG Voyager Keyboard Replacement: étape 8, image 1 de 1
    • Detach the keyboard from the phone by taking off the little metal latches.
    • When replacing the old keyboard with a new one you will have to solder the metal latches to the new board.
Lance Collins
Membre depuis le 04/12/12
7 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-26, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 10
Total : 418
