Aller au contenu principal
LG Voyager Micro SD Replacement
Ce dont vous avez besoin
  1. LG Voyager Micro SD Replacement, Micro SD: étape 1, image 1 de 1
    • Turn the phone onto its side so the label micro SD is facing upside down.
    • Once on its side, lift the micro SD cover up and swivel it away from the opening.
  2. LG Voyager Micro SD Replacement: étape 2, image 1 de 2 LG Voyager Micro SD Replacement: étape 2, image 2 de 2
    • The Micro SD card will appear as a thin plastic piece sticking out of the phone
    • Gently push down on the card, you should hear a click, and then it will "spring" back at you.
    • The card should be sticking out of the phone slightly once this is done.
    • Remove the card from the slot
Michelle
Membre depuis le 04/10/12
20 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 17-26, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 391
