Introduction
The guide will show you how to remove the battery from the laptop. The removal of the battery is necessary to do any work inside the laptop for safety purposes.
Pièces
Aucune pièce nécessaire.
Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel. Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
Ajouter un commentaire
Using a plastic opening tool, pull out the back panel from the laptop. Using a plastic opening tool, pull out the back panel from the laptop.
  • Using a plastic opening tool, pull out the back panel from the laptop.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws. Disconnect the battery connector from the motherboard. Disconnect the battery connector from the motherboard.
  • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
  • Disconnect the battery connector from the motherboard.
Pull the battery outward and remove it from the rest of the laptop.
  • Pull the battery outward and remove it from the rest of the laptop.
The removal of the hard drive isn’t completely necessary in order to access the hard drive for removal.
seattlehudson - Réponse
Julian Escallon
Membre depuis le 27/09/2017
543 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S14-G1, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 79
Total : 541
