Aller au contenu principal
Lenovo Edge 2-1580 Fan Replacement
Ce dont vous avez besoin
  1. Lenovo Edge 2-1580 Fan Replacement, Battery: étape 1, image 1 de 2 Lenovo Edge 2-1580 Fan Replacement, Battery: étape 1, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Lenovo Edge 2-1580 Fan Replacement: étape 2, image 1 de 2 Lenovo Edge 2-1580 Fan Replacement: étape 2, image 2 de 2
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Lenovo Edge 2-1580 Fan Replacement: étape 3, image 1 de 3 Lenovo Edge 2-1580 Fan Replacement: étape 3, image 2 de 3 Lenovo Edge 2-1580 Fan Replacement: étape 3, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  4. Lenovo Edge 2-1580 Fan Replacement: étape 4, image 1 de 1
    • Pull the battery outward and remove it from the rest of the laptop.
  5. Lenovo Edge 2-1580 Fan Replacement, Fan: étape 5, image 1 de 3 Lenovo Edge 2-1580 Fan Replacement, Fan: étape 5, image 2 de 3 Lenovo Edge 2-1580 Fan Replacement, Fan: étape 5, image 3 de 3
    • Remove the 5.4 mm Phillips #0 screw holding the Wireless Network Card.
    • The network card will pop up by itself.
  6. Lenovo Edge 2-1580 Fan Replacement: étape 6, image 1 de 2 Lenovo Edge 2-1580 Fan Replacement: étape 6, image 2 de 2
    • Grab the network card and gently pull it out.
  7. Lenovo Edge 2-1580 Fan Replacement: étape 7, image 1 de 2 Lenovo Edge 2-1580 Fan Replacement: étape 7, image 2 de 2
    • Pull out the RAM metallic cover.
  8. Lenovo Edge 2-1580 Fan Replacement: étape 8, image 1 de 2 Lenovo Edge 2-1580 Fan Replacement: étape 8, image 2 de 2
    • Grab the black insulating tape and pull it out.
  9. Lenovo Edge 2-1580 Fan Replacement: étape 9, image 1 de 2 Lenovo Edge 2-1580 Fan Replacement: étape 9, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the (6) six fan screws from the device.
    • (5) Five copper and (1) one silver Phillips #0 5.4mm screws.
    • Disconnect the fan from the motherboard.
  10. Lenovo Edge 2-1580 Fan Replacement: étape 10, image 1 de 2 Lenovo Edge 2-1580 Fan Replacement: étape 10, image 2 de 2
    • Unplug the Fan connector from its socket on the motherboard.
  11. Lenovo Edge 2-1580 Fan Replacement: étape 11, image 1 de 2 Lenovo Edge 2-1580 Fan Replacement: étape 11, image 2 de 2
    • Carefully remove the fan from the laptop.
Julian Escallon
Membre depuis le 09/27/17
714 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S14-G1, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
4 membres
5 tutoriels rédigés
2 commentaires
Looks like heat sink and fan are one unit. Advice for regular dust cleaning? How was the condition of the factory thermal paste?
cfryhover - Réponse
Where can one find this fan?
Gabriel Rivera - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 645
