Aller au contenu principal
Lenovo Edge 2-1580 Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo Edge 2-1580 Motherboard Replacement, Battery: étape 1, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement, Battery: étape 1, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Lenovo Edge 2-1580 Motherboard Replacement: étape 2, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: étape 2, image 2 de 2
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Lenovo Edge 2-1580 Motherboard Replacement: étape 3, image 1 de 3 Lenovo Edge 2-1580 Motherboard Replacement: étape 3, image 2 de 3 Lenovo Edge 2-1580 Motherboard Replacement: étape 3, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  4. Lenovo Edge 2-1580 Motherboard Replacement: étape 4, image 1 de 1
    • Pull the battery outward and remove it from the rest of the laptop.
  5. Lenovo Edge 2-1580 Motherboard Replacement, Hard drive: étape 5, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement, Hard drive: étape 5, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the (3) three 3 mm screws.
  6. Lenovo Edge 2-1580 Motherboard Replacement: étape 6, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: étape 6, image 2 de 2
    • Slide the drive away from the connector by applying pressure on the two side tabs where screws were removed. Use a plastic opening tool as a lever to lift the drive out.
  7. Lenovo Edge 2-1580 Motherboard Replacement: étape 7, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: étape 7, image 2 de 2
    • Carefully, using your hand, remove the hard drive from the laptop.
  8. Lenovo Edge 2-1580 Motherboard Replacement, Fan: étape 8, image 1 de 3 Lenovo Edge 2-1580 Motherboard Replacement, Fan: étape 8, image 2 de 3 Lenovo Edge 2-1580 Motherboard Replacement, Fan: étape 8, image 3 de 3
    • Remove the 5.4 mm Phillips #0 screw holding the Wireless Network Card.
    • The network card will pop up by itself.
  9. Lenovo Edge 2-1580 Motherboard Replacement: étape 9, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: étape 9, image 2 de 2
    • Grab the network card and gently pull it out.
  10. Lenovo Edge 2-1580 Motherboard Replacement: étape 10, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: étape 10, image 2 de 2
    • Pull out the RAM metallic cover.
  11. Lenovo Edge 2-1580 Motherboard Replacement: étape 11, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: étape 11, image 2 de 2
    • Grab the black insulating tape and pull it out.
  12. Lenovo Edge 2-1580 Motherboard Replacement: étape 12, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: étape 12, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the (6) six fan screws from the device.
    • (5) Five copper and (1) one silver Phillips #0 5.4mm screws.
    • Disconnect the fan from the motherboard.
  13. Lenovo Edge 2-1580 Motherboard Replacement: étape 13, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: étape 13, image 2 de 2
    • Unplug the Fan connector from its socket on the motherboard.
  14. Lenovo Edge 2-1580 Motherboard Replacement: étape 14, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: étape 14, image 2 de 2
    • Carefully remove the fan from the laptop.
  15. Lenovo Edge 2-1580 Motherboard Replacement, Motherboard: étape 15, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement, Motherboard: étape 15, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the (2) two 5.4 mm Phillips screws.
    • Disconnect these connectors from the motherboard.
    • Disconnect the four ribbon cables from the motherboard.
    • Unscrew and remove the (2) two Phillips #0 screws.
  16. Lenovo Edge 2-1580 Motherboard Replacement: étape 16, image 1 de 3 Lenovo Edge 2-1580 Motherboard Replacement: étape 16, image 2 de 3 Lenovo Edge 2-1580 Motherboard Replacement: étape 16, image 3 de 3
    • Lift up the black latch of the ribbon cable with the brown tab on top by holding the cable in to the motherboard.
    • Grab the tab with a pair of pliers and pull out the cable.
  17. Lenovo Edge 2-1580 Motherboard Replacement: étape 17, image 1 de 3 Lenovo Edge 2-1580 Motherboard Replacement: étape 17, image 2 de 3 Lenovo Edge 2-1580 Motherboard Replacement: étape 17, image 3 de 3
    • Lift the beige latch of the ribbon cable with the blue tab by holding the cable in to the motherboard, and with a pair of tweezers, pull out the cable.
  18. Lenovo Edge 2-1580 Motherboard Replacement: étape 18, image 1 de 3 Lenovo Edge 2-1580 Motherboard Replacement: étape 18, image 2 de 3 Lenovo Edge 2-1580 Motherboard Replacement: étape 18, image 3 de 3
    • Lift up the black latch of the ribbon cable with the blue tab at the lower right corner of the motherboard and disconnect it with a pair of tweezers.
    • Grab the tab and pull out the cable.
  19. Lenovo Edge 2-1580 Motherboard Replacement: étape 19, image 1 de 3 Lenovo Edge 2-1580 Motherboard Replacement: étape 19, image 2 de 3 Lenovo Edge 2-1580 Motherboard Replacement: étape 19, image 3 de 3
    • Locate the last ribbon cable with a blue tab and lift the beige latch holding the cable in to the motherboard.
    • With a pair of tweezers grab the tab and remove the cable.
  20. Lenovo Edge 2-1580 Motherboard Replacement: étape 20, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: étape 20, image 2 de 2
    • Lift the black latch of the black connector at the top left corner of the motherboard by holding it in to the motherboard.
    • Grab the cable and pull it outwards to remove it.
  21. Lenovo Edge 2-1580 Motherboard Replacement: étape 21, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: étape 21, image 2 de 2
    • Pull the wire besides the brown tab ribbon cable out and disconnect it.
  22. Lenovo Edge 2-1580 Motherboard Replacement: étape 22, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: étape 22, image 2 de 2
    • Grab the small black connector by the RAM module and disconnect it from the motherboard.
  23. Lenovo Edge 2-1580 Motherboard Replacement: étape 23, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: étape 23, image 2 de 2
    • Unplug the remaining connector besides the RAM module and remove it from the motherboard.
  24. Lenovo Edge 2-1580 Motherboard Replacement: étape 24, image 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: étape 24, image 2 de 2
    • Gently grab the motherboard and pull it up lightly. Then pull it towards you and remove the motherboard.
4 autres ont terminé cette réparation.
Julian Escallon
Membre depuis le 09/27/17
714 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S14-G1, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 2,129
