Aller au contenu principal
Lenovo Edge 2-1580 Storage Replacement
Ce dont vous avez besoin
  1. Lenovo Edge 2-1580 Storage Replacement, Battery: étape 1, image 1 de 2 Lenovo Edge 2-1580 Storage Replacement, Battery: étape 1, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Lenovo Edge 2-1580 Storage Replacement: étape 2, image 1 de 2 Lenovo Edge 2-1580 Storage Replacement: étape 2, image 2 de 2
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Lenovo Edge 2-1580 Storage Replacement: étape 3, image 1 de 3 Lenovo Edge 2-1580 Storage Replacement: étape 3, image 2 de 3 Lenovo Edge 2-1580 Storage Replacement: étape 3, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  4. Lenovo Edge 2-1580 Storage Replacement: étape 4, image 1 de 1
    • Pull the battery outward and remove it from the rest of the laptop.
  5. Lenovo Edge 2-1580 Storage Replacement, Hard drive: étape 5, image 1 de 2 Lenovo Edge 2-1580 Storage Replacement, Hard drive: étape 5, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the (3) three 3 mm screws.
  6. Lenovo Edge 2-1580 Storage Replacement: étape 6, image 1 de 2 Lenovo Edge 2-1580 Storage Replacement: étape 6, image 2 de 2
    • Slide the drive away from the connector by applying pressure on the two side tabs where screws were removed. Use a plastic opening tool as a lever to lift the drive out.
  7. Lenovo Edge 2-1580 Storage Replacement: étape 7, image 1 de 2 Lenovo Edge 2-1580 Storage Replacement: étape 7, image 2 de 2
    • Carefully, using your hand, remove the hard drive from the laptop.
5 autres ont terminé cette réparation.
Julian Escallon
Membre depuis le 09/27/17
714 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S14-G1, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
4 membres
5 tutoriels rédigés
3 commentaires
The Edge 2 requires a hard drive of 7mm or less or the bottom cover will not fit properly.
randylovely - Réponse
Thank you, was looking everywhere to find that out!!!
christopher busse -
Thank you, your help was so useful.
Alejandro E Jecke - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 11
Total : 4,083
