Introduction
This guide is only used as a precursor to the hard drive, RAM, and keyboard removal.
Pièces
Aucune pièce nécessaire.
Turn off the computer.
  • Turn off the computer.
  • Disconnect the charging cable from the computer.
  • Failure to unplug the cable could result in electric shock.
  • Flip the computer upside down.
Ajouter un commentaire
Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position. Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
Remove the seven 5.3 mm Phillips  #1 screws holding the back panel in place.
  • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly. If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
  • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
  • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
3 autre(s) ont terminé cette réparation.
Lawrence Downs
Membre depuis le 11/01/2013
263 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 18-40, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 36
Total : 3,583
