Aller au contenu principal
Lenovo Essential G570 Keyboard Replacement
Ce dont vous avez besoin
  1. Lenovo Essential G570 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to unplug the cable could result in electric shock.
    • Turn the computer upside down.
  2. Lenovo Essential G570 Keyboard Replacement: étape 2, image 1 de 2 Lenovo Essential G570 Keyboard Replacement: étape 2, image 2 de 2
    • Locate the two switches that lock the battery.
    • Push the right switch outwards to unlock the battery.
  3. Lenovo Essential G570 Keyboard Replacement: étape 3, image 1 de 2 Lenovo Essential G570 Keyboard Replacement: étape 3, image 2 de 2
    • Push and hold the left switch outwards to unlock the battery.
    • Pull the battery away from the computer.
  4. Lenovo Essential G570 Keyboard Replacement, Back Panel: étape 4, image 1 de 1
    • Turn the laptop over so that the bottom side is facing up.
  5. Lenovo Essential G570 Keyboard Replacement: étape 5, image 1 de 1
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
  6. Lenovo Essential G570 Keyboard Replacement: étape 6, image 1 de 3 Lenovo Essential G570 Keyboard Replacement: étape 6, image 2 de 3 Lenovo Essential G570 Keyboard Replacement: étape 6, image 3 de 3
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
  7. Lenovo Essential G570 Keyboard Replacement, Keyboard: étape 7, image 1 de 1
    • Remove the two 9mm Phillips #0 screws.
    • Remove the single 5mm Phillips #0 screw.
    • All 3 screws are located next to keyboard icons.
  8. Lenovo Essential G570 Keyboard Replacement: étape 8, image 1 de 2 Lenovo Essential G570 Keyboard Replacement: étape 8, image 2 de 2
    • Flip the computer over and open it.
    • Using the plastic opening tool, pry open the top of the keyboard.
  9. Lenovo Essential G570 Keyboard Replacement: étape 9, image 1 de 1
    • Remove the keyboard by gently pulling the top of the keyboard loose, and then lifting the keyboard out.
    • Be careful lifting the keyboard up because there is a delicate ribbon cable connected to the bottom.
  10. Lenovo Essential G570 Keyboard Replacement: étape 10, image 1 de 3 Lenovo Essential G570 Keyboard Replacement: étape 10, image 2 de 3 Lenovo Essential G570 Keyboard Replacement: étape 10, image 3 de 3
    • While lifting the keyboard, push the black latch on the keyboard cable ZIF connector forward to unlock it.
    • Carefully pull away the ribbon cable to detach it from the motherboard.
    • Be careful when unlatching the lock on the keyboard cable ZIF connector. It is extremely delicate and can easily break.
4 autres ont terminé cette réparation.
Nina Francisco
Membre depuis le 03/01/18
385 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G1, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S1-G1, Simcock Spring 2018
UMASSD-SIMCOCK-S18S1G1
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 2,433
