Introduction
Replacing the keyboard is a quick and easy task. Removing the keyboard only took three tools: A JIS #1 screwdriver, plastic opening tool, and tweezers. Before you start make sure you remove the battery and unplug the device.
Pièces
Aucune pièce nécessaire.
At the top of the laptop you will see two switches, like in image one and two. Pull the switches outwards with your thumb, towards the unlocked lock. Pull the switches outwards with your thumb, towards the unlocked lock.
  • At the top of the laptop you will see two switches, like in image one and two.
  • Pull the switches outwards with your thumb, towards the unlocked lock.
Ajouter un commentaire
Once both switches are pulled, the battery should pop out. Once both switches are pulled, the battery should pop out. Once both switches are pulled, the battery should pop out.
  • Once both switches are pulled, the battery should pop out.
Now you are ready to insert your new battery.
  • Now you are ready to insert your new battery.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use a JIS #1 screwdriver to remove the two 7 mm screws. Use a JIS #1 screwdriver to remove the two 7 mm screws.
  • Use a JIS #1 screwdriver to remove the two 7 mm screws.
Remove the back panel by sliding it away from the battery. Remove the back panel by sliding it away from the battery.
  • Remove the back panel by sliding it away from the battery.
Use a JIS #1 screwdriver to remove the three 7 mm screws.
  • Use a JIS #1 screwdriver to remove the three 7 mm screws.
Wedge the plastic opening tool in-between the keyboard and the base of the laptop. Continue using the plastic opening tool to pry around the edge  until the keyboard is completely freed form the frame.
  • Wedge the plastic opening tool in-between the keyboard and the base of the laptop.
  • Continue using the plastic opening tool to pry around the edge until the keyboard is completely freed form the frame.
  • The keyboard should only be connected by a ribbon on the underside of the keyboard.
  • It is recommended that you slowly pull the keyboard out as your move around the edge. As in picture 2.
  • Be careful not to pull the keyboard too far away from the face as it will damage the data ribbon.
Use the tweezers to lift the black hinge on the ribbon connector. Then pull the ribbon from the connector and remove the keyboard from the laptop. Then pull the ribbon from the connector and remove the keyboard from the laptop.
  • Use the tweezers to lift the black hinge on the ribbon connector.
  • Then pull the ribbon from the connector and remove the keyboard from the laptop.
Now your keyboard is free to be replaced!
  • Now your keyboard is free to be replaced!
Luke
Membre depuis le 08/02/2018
233 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team S16-G4, Nardone Spring 2018 Membre de l'équipe Sam Houston State, Team S16-G4, Nardone Spring 2018
SHSU-NARDONE-S18S16G4
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 31
Total : 80
