Aller au contenu principal
Lenovo G40-30 Keyboard Replacement
Ce dont vous avez besoin
  1. Lenovo G40-30 Keyboard Replacement, Battery: étape 1, image 1 de 3 Lenovo G40-30 Keyboard Replacement, Battery: étape 1, image 2 de 3 Lenovo G40-30 Keyboard Replacement, Battery: étape 1, image 3 de 3
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 Keyboard Replacement: étape 2, image 1 de 3 Lenovo G40-30 Keyboard Replacement: étape 2, image 2 de 3 Lenovo G40-30 Keyboard Replacement: étape 2, image 3 de 3
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 Keyboard Replacement: étape 3, image 1 de 1
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 Keyboard Replacement, Keyboard: étape 4, image 1 de 2 Lenovo G40-30 Keyboard Replacement, Keyboard: étape 4, image 2 de 2
    • Use a JIS #1 screwdriver to remove the two 7 mm screws.
  5. Lenovo G40-30 Keyboard Replacement: étape 5, image 1 de 2 Lenovo G40-30 Keyboard Replacement: étape 5, image 2 de 2
    • Remove the back panel by sliding it away from the battery.
  6. Lenovo G40-30 Keyboard Replacement: étape 6, image 1 de 1
    • Use a JIS #1 screwdriver to remove the three 7 mm screws.
  7. Lenovo G40-30 Keyboard Replacement: étape 7, image 1 de 2 Lenovo G40-30 Keyboard Replacement: étape 7, image 2 de 2
    • Wedge the plastic opening tool in-between the keyboard and the base of the laptop.
    • Continue using the plastic opening tool to pry around the edge until the keyboard is completely freed form the frame.
    • The keyboard should only be connected by a ribbon on the underside of the keyboard.
    • It is recommended that you slowly pull the keyboard out as your move around the edge. As in picture 2.
    • Be careful not to pull the keyboard too far away from the face as it will damage the data ribbon.
  8. Lenovo G40-30 Keyboard Replacement: étape 8, image 1 de 3 Lenovo G40-30 Keyboard Replacement: étape 8, image 2 de 3 Lenovo G40-30 Keyboard Replacement: étape 8, image 3 de 3
    • Use the tweezers to lift the black hinge on the ribbon connector.
    • Then pull the ribbon from the connector and remove the keyboard from the laptop.
  9. Lenovo G40-30 Keyboard Replacement: étape 9, image 1 de 1
    • Now your keyboard is free to be replaced!
2 autres ont terminé cette réparation.
Luke
Membre depuis le 02/08/18
314 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team S16-G4, Nardone Spring 2018 Membre de l'équipe Sam Houston State, Team S16-G4, Nardone Spring 2018
SHSU-NARDONE-S18S16G4
5 membres
5 tutoriels rédigés
Un commentaire
thanks ….terimakasih sangat membantu…..
herman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 6
Total : 2,076
