Introduction
This requires only a Phillips head screwdriver. Be aware that only 2.5" hard drives fit in this computer.
Pièces
Aucune pièce nécessaire.
Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
  • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
  • Make sure that the work surface is flat and has nothing sharp on it.
Ajouter un commentaire
Remove the monitor stand screw in the bottom of the stand, and remove the stand completely. Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
Remove the two screws on the bottom of the computer, one on each side.
  • Remove the two screws on the bottom of the computer, one on each side.
Idées cadeaux pour la Fête des Pères
Mettons nos papas à l’honneur ainsi que nos mentors qui nous ont appris à réparer.
Honorons ceux qui nous ont enseigné à réparer.
Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.) Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.) Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
Once it has been separated, lift to remove. Once it has been separated, lift to remove.
  • Once it has been separated, lift to remove.
Unscrew the four screws that secure the hard drive enclosure. Unscrew the four screws that secure the hard drive enclosure.
  • Unscrew the four screws that secure the hard drive enclosure.
Unplug the SATA cable. Lift to remove the hard drive enclosure.
  • Unplug the SATA cable. Lift to remove the hard drive enclosure.
Unscrew the four screws that hold hard drive enclosure to the hard drive, located on the side of the enclosure. Unscrew the four screws that hold hard drive enclosure to the hard drive, located on the side of the enclosure.
  • Unscrew the four screws that hold hard drive enclosure to the hard drive, located on the side of the enclosure.
Lift the hard drive up to remove it from the enclosure.
  • Lift the hard drive up to remove it from the enclosure.
Jackson Blake
Membre depuis le 22/01/2018
805 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team S16-G3, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 18
30 derniers jours : 89
Total : 160
