Pièces
Aucune pièce nécessaire.
Lay the computer down on its side as shown.
  • Lay the computer down on its side as shown.
  • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
Ajouter un commentaire
Gently slide the side panel straight back and remove from the computer.
  • Gently slide the side panel straight back and remove from the computer.
With your hands remove the 14mm screw that holds the cover on the back panel.
  • With your hands remove the 14mm screw that holds the cover on the back panel.
  • Gently pull the flap back to expose the T.V. Tuner screw.
Use the Phillips #2 to remove the 8mm screw that holds the T.V. Tuner in place.
  • Use the Phillips #2 to remove the 8mm screw that holds the T.V. Tuner in place.
With moderate force, pull straight up on the chip to remove it from the computer.
  • With moderate force, pull straight up on the chip to remove it from the computer.
2 autre(s) ont terminé cette réparation.
Timothy Grebe
Membre depuis le 19/10/2014
1 304 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 10-39, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 407
