Aller au contenu principal
Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement, Back Case: étape 1, image 1 de 1
    • Remove the thirteen 6 mm Phillips #0 screws.
  2. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: étape 2, image 1 de 2 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: étape 2, image 2 de 2
    • Use an opening tool to gently disconnect most of the clips on the back panel.
    • DO NOT force the panel out towards the optical disk drive.
  3. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: étape 3, image 1 de 3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: étape 3, image 2 de 3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: étape 3, image 3 de 3
    • Pry the disk drive away from the center of the laptop.
    • Don't worry about any screws since we already removed the screws that are associated with the drive.
    • Once the drive is removed, remove the one 2 mm Phillips #0 screw that is now exposed.
  4. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: étape 4, image 1 de 3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: étape 4, image 2 de 3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: étape 4, image 3 de 3
    • Unclip any of the remaining clips and remove the back panel.
  5. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement, Battery Replacement: étape 5, image 1 de 1
    • Remove the four 6 mm Phillips #0 mounting screws.
  6. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: étape 6, image 1 de 3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: étape 6, image 2 de 3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: étape 6, image 3 de 3
    • Detach the wire connected to the motherboard and remove the battery assembly.
  7. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement, Hard Disk Drive Replacement: étape 7, image 1 de 1
    • Remove the four 4 mm Phillips #0 mounting screws attaching the caddy to the frame.
  8. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: étape 8, image 1 de 2 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: étape 8, image 2 de 2
    • Gently remove the caddy away from the motherboard.
    • If you are removing an already existing HDD, unplug the component along with the caddy and remove the four screws mounting the caddy to the HDD.
Clark Beuckman
Membre depuis le 02/22/22
544 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 2-3, Hunter Spring 2022 Membre de l'équipe Clemson, Team 2-3, Hunter Spring 2022
CLEM-HUNTER-S22S2G3
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 23
Total : 376
