Aller au contenu principal
Lenovo IdeaPad 110 Touch-15ACL Screen Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Back Case: étape 1, image 1 de 1
    • Remove the thirteen 6 mm Phillips #0 screws.
  2. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 2, image 1 de 2 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 2, image 2 de 2
    • Use an opening tool to gently disconnect most of the clips on the back panel.
    • DO NOT force the panel out towards the optical disk drive.
  3. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 3, image 1 de 3 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 3, image 2 de 3 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 3, image 3 de 3
    • Pry the disk drive away from the center of the laptop.
    • Don't worry about any screws since we already removed the screws that are associated with the drive.
    • Once the drive is removed, remove the one 2 mm Phillips #0 screw that is now exposed.
  4. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 4, image 1 de 3 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 4, image 2 de 3 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 4, image 3 de 3
    • Unclip any of the remaining clips and remove the back panel.
  5. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Battery Replacement: étape 5, image 1 de 1
    • Remove the four 6 mm Phillips #0 mounting screws.
  6. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 6, image 1 de 3 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 6, image 2 de 3 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 6, image 3 de 3
    • Detach the wire connected to the motherboard and remove the battery assembly.
  7. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Screen Replacement: étape 7, image 1 de 3 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Screen Replacement: étape 7, image 2 de 3 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Screen Replacement: étape 7, image 3 de 3
    • Open the laptop so the screen is facing you.
    • Use a pick or spudger to detach the clips around the screen holding the bezel in place.
    • Remove the bezel.
  8. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 8, image 1 de 3 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 8, image 2 de 3 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 8, image 3 de 3
    • Remove the four 3 mm size Phillips #0 mounting screws.
  9. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 9, image 1 de 3 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 9, image 2 de 3 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: étape 9, image 3 de 3
    • Carefully detach the display cable that attaches to the display.
    • There may be a piece of tape covering the connection. Be sure to preserve this if possible—it ensures a proper connection to your display.
Clark Beuckman
Membre depuis le 02/22/22
544 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 2-3, Hunter Spring 2022 Membre de l'équipe Clemson, Team 2-3, Hunter Spring 2022
CLEM-HUNTER-S22S2G3
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 9
Total : 149
