Aller au contenu principal
Lenovo IdeaPad 110-15IBR Optical Drive Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 110-15IBR Optical Drive Replacement, Optical Drive: étape 1, image 1 de 2 Lenovo IdeaPad 110-15IBR Optical Drive Replacement, Optical Drive: étape 1, image 2 de 2
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source.
    • Using #1 Phillips screwdriver remove the 13 (9mmx6mm) screws holding the back.
    • Gently pry the back off using a plastic opening tool, starting from one of the corners.
  2. Lenovo IdeaPad 110-15IBR Optical Drive Replacement: étape 2, image 1 de 1
    • Using #1 Phillips screwdriver remove the 1 (9mmx6mm) screw holding the disk drive in place.
  3. Lenovo IdeaPad 110-15IBR Optical Drive Replacement: étape 3, image 1 de 1
    • Pull the optical drive away from device to slide out of dock.
    • Careful not to pull the drive straight up or towards the device, otherwise damage might be done to the drive connector.
5 autres ont terminé cette réparation.
Saddam Alsinai
Membre depuis le 10/18/17
669 Réputation
4 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G4, Liner Fall 2017 Membre de l'équipe UW Tacoma, Team S3-G4, Liner Fall 2017
UWT-LINER-F17S3G4
4 membres
14 tutoriels rédigés
Un commentaire
I think there is an easier way to remove the optical drive. You only need to remove the screw in the middle near optical drive. After this you can pull out the otpical drive.
Max Härtwig - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 17
Total : 3,626
