Aller au contenu principal
Lenovo IdeaPad 110-15ISK RAM Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 110-15ISK RAM Replacement, Keyboard: étape 1, image 1 de 1
    • Flip the IdeaPad bottom side up.
    • Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
    • Flip the computer back to top facing.
  2. Lenovo IdeaPad 110-15ISK RAM Replacement: étape 2, image 1 de 1
    • Open the lid.
    • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
  3. Lenovo IdeaPad 110-15ISK RAM Replacement: étape 3, image 1 de 1
    • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Completely remove the keyboard from the bottom assembly.
    • Unlock the ZIF conector before pulling the cable out
  4. Lenovo IdeaPad 110-15ISK RAM Replacement, Optical Drive: étape 5, image 1 de 1
    • Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
  5. Lenovo IdeaPad 110-15ISK RAM Replacement: étape 6, image 1 de 1
    • Flip the laptop to its back and the optical drive is located at the top left corner.
    • Remove the optical CD DVD drive by lightly pulling it out of the assembly.
  6. Lenovo IdeaPad 110-15ISK RAM Replacement, Upper Case: étape 7, image 1 de 1
    • Place the laptop bottom facing up.
    • Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
  7. Lenovo IdeaPad 110-15ISK RAM Replacement: étape 8, image 1 de 1
    • Separate the top case from the bottom using a plastic opening tool.
    • Continue prying the top and bottom case from each other all around the perimeter of the laptop.
  8. Lenovo IdeaPad 110-15ISK RAM Replacement, Battery: étape 9, image 1 de 1
    • Turn the laptop upside down and gently pry the top case free from the bottom case.
  9. Lenovo IdeaPad 110-15ISK RAM Replacement: étape 10, image 1 de 1
    • The battery is attached to the bottom case of the laptop.
    • Remove the two 4.0mm screws.
    • Push the battery component away from you in order to completely remove the battery from the fixture.
  10. Lenovo IdeaPad 110-15ISK RAM Replacement, RAM: étape 11, image 1 de 1
    • On the back panel, the RAM is located at the bottom of the logic board.
    • Press the silver two hinges at the bottom corners of the RAM to loosen the RAM.
    • Remove the loosened RAM from the back panel.
5 autres ont terminé cette réparation.
Jakub Szark
Membre depuis le 10/17/18
513 Réputation
5 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G5, Rose Fall 2018 Membre de l'équipe UW Tacoma, Team S1-G5, Rose Fall 2018
UWT-ROSE-F18S1G5
4 membres
39 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 50
30 derniers jours : 179
Total : 11,286
