Aller au contenu principal
Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Lower Case: étape 1, image 1 de 1
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: étape 2, image 1 de 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: étape 2, image 2 de 2
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: étape 3, image 1 de 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: étape 3, image 2 de 2
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: étape 4, image 1 de 3 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: étape 4, image 2 de 3 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: étape 4, image 3 de 3
    • Release the remaining clasp and remove the lower case.
  5. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Hard Disk Drive (HDD): étape 5, image 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the four 5 mm screws that are holding the hard drive in place.
  6. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: étape 6, image 1 de 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: étape 6, image 2 de 2
    • Do not lift the hard drive straight up; this might break the connection port.
    • Softly slide the hard drive away from the port.
  7. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: étape 7, image 1 de 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: étape 7, image 2 de 2
    • Use a Phillips #1 screwdriver remove the 2 screws from both sides of the hard drive (total of 4 screws).
  8. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: étape 8, image 1 de 1
    • Remove the hard drive from the housing mount.
Cameron Mounce
Membre depuis le 09/05/23
668 Réputation
5 tutoriels rédigés
Équipe
Gateway, Team 1-3, Pee Fall 2023 Membre de l'équipe Gateway, Team 1-3, Pee Fall 2023
GCC-PEE-F23S1G3
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 119
