Introduction
Use this guide to remove the Motherboard from the Lenovo IdeaPad 130-15AST. The motherboard of your computer is a giant circuit board inside of your desktop or laptop computer. Between all the components run silver lines of conductive metal, "wires' fused directly to the motherboard's insulating plastic. The conductors sometimes break or melt; or a component that cannot be easily removed burns out. This could happen as a result of a power surge due, a lightning strike, or because of a manufacturing defect. With those results you will need to replace your motherboard. Follow the steps in the Replacement Guide carefully to remove the motherboard safely and efficiently.
Ce dont vous avez besoin
Using a Phillips #00 screwdriver, remove one of the 6.0mm screws.
Using a prying tool, remove the white plug (which includes 4 different colored wires) from the motherboard. Repeat the same step for the other plug.
Gently move the wires wrapped around the fan that run along the left side of the cooling fan.
3 autres ont terminé cette réparation.
Un commentaire
Where can I find an Intel replacement motherboard instead of the stupid AMD a6 one?
