Aller au contenu principal
Lenovo IdeaPad 3-15IIL05 Back Cover Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Unfasten the back cover: étape 1, image 1 de 2 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Unfasten the back cover: étape 1, image 2 de 2
    • Use a Phillips screwdriver to remove the ten screws securing the back cover:
    • Six 7.6 mm-long screws
    • Four 4.7 mm-long screws
  2. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: étape 2, image 1 de 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: étape 2, image 2 de 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: étape 2, image 3 de 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the top left corner of the back cover and frame.
    • Angle the pick down to about 45 degrees.
  3. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the left clips: étape 3, image 1 de 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the left clips: étape 3, image 2 de 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the left clips: étape 3, image 3 de 3
    • Keep the opening pick angled down at about 45 degrees while sliding it along the front and side edges to help release the clips.
    • Slide the pick to the bottom left corner of the laptop to release the left clips.
  4. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the bottom clips: étape 4, image 1 de 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the bottom clips: étape 4, image 2 de 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the bottom clips: étape 4, image 3 de 3
    • Slide the opening pick to the bottom right corner to release the bottom clips.
  5. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the right clips: étape 5, image 1 de 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the right clips: étape 5, image 2 de 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the right clips: étape 5, image 3 de 3
    • Slide the opening pick to the top right corner to release the right clips.
  6. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: étape 6, image 1 de 2 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: étape 6, image 2 de 2
    • Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
    • Pry the back cover up with the pick to release the top right clips.
    • Leave the pick inserted next to the right hinge.
  7. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the top clips: étape 7, image 1 de 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the top clips: étape 7, image 2 de 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the top clips: étape 7, image 3 de 3
    • Angle the pick up to about 45 degrees.
    • Slide the opening pick to the top left corner to release the remaining clips.
  8. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Remove the back cover: étape 8, image 1 de 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Remove the back cover: étape 8, image 2 de 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Remove the back cover: étape 8, image 3 de 3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
Spencer Day
Membre depuis le 09/14/22
55 203 Réputation
408 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 430 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 71
30 derniers jours : 293
Total : 1,399
