Aller au contenu principal
Lenovo IdeaPad 300-17ISK Hard Drive Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Bottom Back Cover: étape 1, image 1 de 1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: étape 2, image 1 de 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: étape 2, image 2 de 2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • The hard drive is located at the bottom of the laptop.
  4. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: étape 4, image 1 de 1
    • Unscrew the four 6mm Phillips #1 screws that hold the hard drive frame in place.
  5. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: étape 5, image 1 de 1
    • Gently pick up the hard drive without pulling it completely out.
    • You shouldn't use excessive force because the hard drive is still attached to the motherboard.
  6. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: étape 6, image 1 de 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: étape 6, image 2 de 2
    • Use the spudger to disconnect the hard drive from it motherboard connector.
    • The connector should come right off without excessive force.
  7. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: étape 7, image 1 de 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: étape 7, image 2 de 2
    • Remove the four 3mm Phillips #1 screws, two on each side, that secure the hard drive in its protective frame.
    • These screws are different from the rest of the laptop screws. You can damage the drive using the wrong screws.
    • Lift the frame to separate it from the hard drive.
10 autres ont terminé cette réparation.
Ammar Dodin
Membre depuis le 01/19/17
1 057 Réputation
6 tutoriels rédigés
Équipe
UC Davis, Team 1-3, Rodger Winter 2017 Membre de l'équipe UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 membres
6 tutoriels rédigés
3 commentaires
Clear and easy - thanks!
Beth Pierce - Réponse
Very good and to the point
al_stewart - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 49
Total : 9,685
