Aller au contenu principal
Lenovo IdeaPad 300-17ISK Optical Drive Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Keyboard: étape 1, image 1 de 1
    • Unscrew the three 6mm Phillips #1 screws from the upper back cover.
  2. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: étape 2, image 1 de 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: étape 2, image 2 de 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: étape 2, image 3 de 3
    • Place the opening tool's head under any edge of the keyboard.
    • Pull upwards to unsnap the keyboard.
    • Use your fingers and the opening tool to pop the keyboard out of its place.
    • You should't use any excessive force because the keyboard is still attached to the motherboard.
  3. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: étape 3, image 1 de 2 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: étape 3, image 2 de 2
    • Push the keyboard connector latch upwards with the spudger.
    • You shouldn't use excessive force. The connector latch is very fragile.
    • The keyboard connector cable should slide right out.
  4. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Optical Drive: étape 4, image 1 de 1
    • Remove the 6mm Phillips #1 screw that sits in the center of the front plate below the keyboard. This screw sits between two adjacent tabbed holes.
  5. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: étape 5, image 1 de 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: étape 5, image 2 de 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: étape 5, image 3 de 3
    • Insert the opening tool's head into one of the tabbed holes.
    • With the opening tool's head inserted under a tab, push to the right. The optical drive should slide out easily.
Ammar Dodin
Membre depuis le 01/19/17
1 057 Réputation
6 tutoriels rédigés
Équipe
UC Davis, Team 1-3, Rodger Winter 2017 Membre de l'équipe UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 30
Total : 5,064
