Aller au contenu principal
Lenovo IdeaPad 330S Fan and Thermal Unit
Ce dont vous avez besoin
  1. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: étape 1, image 1 de 2 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: étape 1, image 2 de 2
    • Turn off the device and disconnect from the power.
    • Remove the 10 screws as shown in picture.
    • Using a plastic pry tool remove the bottom case (gently).
  2. Lenovo IdeaPad 330S Fan and Thermal Unit, Disconnecting Battery: étape 2, image 1 de 1
    • Using a spudger gently push the black connector to the left (red circle).
    • If you want to remove the battery by removing the five screws labeled in blue.
  3. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: étape 3, image 1 de 2 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: étape 3, image 2 de 2
    • Remove the 3 screws that are circuled in blue. Then remove the red one.
    • The red circle is a M2.5 and the blue circle are M2.0 those are different screws!
    • Remove the black shield
  4. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing Cooling Fan: étape 4, image 1 de 1
    • Remove the two black screws that are marked in red
    • Disconnect the fan (blue marker) from MB by pushing gently to the left using a spudger.
  5. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing the Thermal unit: étape 5, image 1 de 1
    • Remove the 6 screws in revrse of the number stated on screws.
    • Replace the thermal paste with a fresh one
    • Removing the fan is not needed but will help with easier dissemble of thermal unit
3 autres ont terminé cette réparation.
Ilia Tocheny
Membre depuis le 04/30/19
1 616 Réputation
9 tutoriels rédigés
2 commentaires
I want to buy this piece, where can I find it for purchase?
c.lobos_7 - Réponse
Good question, you could try at your local Lenovo Service provider.
Ilia Tocheny - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 17
Total : 1,590
