Introduction
Your screen might need replacement if there are any noticeable cracks on screen or if you are experiencing persistent flickering during use of your Lenovo IdeaPad Flex4-1130.
Pièces
Aucune pièce nécessaire.
Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
  • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
  • Remove the ten 4mm screws from the back panel.
Ajouter un commentaire
Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
  • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
  • Do not insert the spudger too deep! This could potentially damage a device part.
Remove the connector attaching the battery to the motherboard.
  • Remove the connector attaching the battery to the motherboard.
Remove the four 4mm screws on the battery.
  • Remove the four 4mm screws on the battery.
Lift the battery with a spudger and remove.
  • Lift the battery with a spudger and remove.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove six 7mm screws. Remove six 7mm screws.
  • Remove six 7mm screws.
Remove two connector cables. Separate the two unhinged parts.
  • Remove two connector cables.
  • Separate the two unhinged parts.
Use the spudger to remove the plastic caps, uncovering the screws underneath.
  • Use the spudger to remove the plastic caps, uncovering the screws underneath.
  • Remove the two 6mm screws.
Use the black nylon spudger to remove the long plastic covering underneath the screen. Remove three 6mm screws.
  • Use the black nylon spudger to remove the long plastic covering underneath the screen.
  • Remove three 6mm screws.
Use the black nylon spudger to lift and separate the screen from the plastic back cover. Use the black nylon spudger to lift and separate the screen from the plastic back cover.
  • Use the black nylon spudger to lift and separate the screen from the plastic back cover.
Peel off tape and remove the cable. Peel off tape and remove the cable.
  • Peel off tape and remove the cable.
Remove the connector chip. Remove the connector chip.
  • Remove the connector chip.
Peel tape and remove cable underneath. Peel tape and remove cable underneath.
  • Peel tape and remove cable underneath.
Adrian Miranda
Membre depuis le 15/02/2018
677 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S17-G5, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S17-G5, Boczar Spring 2018
USFT-BOCZAR-S18S17G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 28
Total : 45
