Aller au contenu principal
Lenovo IdeaPad Flex 4-1470 Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Lower Case: étape 1, image 1 de 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: étape 2, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: étape 2, image 2 de 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: étape 3, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: étape 3, image 2 de 2
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: étape 4, image 1 de 3 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: étape 4, image 2 de 3 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: étape 5, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: étape 5, image 2 de 2
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Wifi Card: étape 6, image 1 de 1
    • Remove the foam on the WIFI card.
  7. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: étape 7, image 1 de 1
    • Remove the wires attached to the WIFI card.
  8. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: étape 8, image 1 de 1
    • Unscrew the 4mm screw holding wifi card.
  9. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Motherboard: étape 9, image 1 de 1
    • Unscrew the twelve 4mm screws with a #0 Phillips screwdriver.
  10. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: étape 10, image 1 de 1
    • Remove the motherboard.
    • The motherboard will be in place when the screw holes line up.
2 autres ont terminé cette réparation.
Elijah Ellis
Membre depuis le 11/08/18
616 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 Membre de l'équipe UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 21
Total : 1,290
