Aller au contenu principal
Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement, Back Panel: étape 1, image 1 de 1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: étape 2, image 1 de 2 Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: étape 2, image 2 de 2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement, Wireless Network Adapter: étape 3, image 1 de 2 Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement, Wireless Network Adapter: étape 3, image 2 de 2
    • Use the reverse tweezers to carefully unplug the two wired connections.
    • Be careful when removing the wire connections to avoid damage to the metal connections on the adapter.
  4. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: étape 4, image 1 de 2 Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: étape 4, image 2 de 2
    • Using the Phillips #00 screwdriver, remove one 3.6 mm screw.
  5. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: étape 5, image 1 de 1
    • Remove the wireless network adapter.
Emily Lau
Membre depuis le 01/23/20
120 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S2-G5, White Winter 2020 Membre de l'équipe Cal Poly, Team S2-G5, White Winter 2020
CPSU-WHITE-W20S2G5
4 membres
16 tutoriels rédigés
Un commentaire
Thank you!
My problem now is the replacement of the tiny male connectors which hooks onto the chip. They are shown in the last image above at the end of the white wire!
I do not know where to get them, given that mine were broken off.
I would deeply appreciate your help in identifying this type of connectors and locating a sources!
Apart from that, as usual, an excellent and up-to-the-point review.
Thank you again.
Dr. Khaled Bizri,
(650) 796 5864
Khaled.Bizri@GMail.com
Khaled Bizri - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 18
30 derniers jours : 49
Total : 4,530
