Aller au contenu principal
Lenovo IdeaPad G50-45 Screen Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad G50-45 Screen Replacement, Screen: étape 1, image 1 de 1
    • Remove the bezel by using the iFixit plastic opening tool to lift up an edge.
    • The bezel is the plastic lining along the edge of the screen.
  2. Lenovo IdeaPad G50-45 Screen Replacement: étape 2, image 1 de 1
    • Finish removing the bezel by using your hand on the inside of the screen and popping it off.
    • If part of the bezel is stuck, start on the opposite side and work your way back to the area that is stuck.
    • The plastic on the hinges will pop off with the rest of the bezel.
  3. Lenovo IdeaPad G50-45 Screen Replacement: étape 3, image 1 de 3 Lenovo IdeaPad G50-45 Screen Replacement: étape 3, image 2 de 3 Lenovo IdeaPad G50-45 Screen Replacement: étape 3, image 3 de 3
    • Remove the 4 screws located in each corner of the screen using the Phillips #2 screwdriver.
  4. Lenovo IdeaPad G50-45 Screen Replacement: étape 4, image 1 de 1
    • Peel back the sticker that attaches the connector to the back of the screen.
    • Disconnect the cable that connects the screen to the computer.
    • There may be two cables.
  5. Lenovo IdeaPad G50-45 Screen Replacement: étape 5, image 1 de 1
    • Test the new screen by turning it on before putting the bezel back on.
6 autres ont terminé cette réparation.
Jessy McDermott
Membre depuis le 10/26/15
200 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Membre de l'équipe UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 membres
5 tutoriels rédigés
2 commentaires
The tutorial was pretty straightforward, and worked.
Remy G - Réponse
My Laptop is got work the searen is blue it what trun on
Rebecca - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 31
Total : 7,855
