Aller au contenu principal
Lenovo IdeaPad N580 Keyboard and Trackpad Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad N580 Keyboard and Trackpad Replacement, Battery: étape 1, image 1 de 1
    • Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
  2. Lenovo IdeaPad N580 Keyboard and Trackpad Replacement: étape 2, image 1 de 1
    • Move the right switch towards the right until it clicks in place. You should then see the color red reveal from where the switch was originally.
  3. Lenovo IdeaPad N580 Keyboard and Trackpad Replacement: étape 3, image 1 de 1
    • Now take your left hand and slide the left switch to the left.
    • This switch will not click in place like the other switch, so make sure to keep your left hand on the switch.
  4. Lenovo IdeaPad N580 Keyboard and Trackpad Replacement: étape 4, image 1 de 1
    • Take your free hand and place it on the battery. Gently slide it away from its slot.
  5. Lenovo IdeaPad N580 Keyboard and Trackpad Replacement, Keyboard and Trackpad: étape 5, image 1 de 3 Lenovo IdeaPad N580 Keyboard and Trackpad Replacement, Keyboard and Trackpad: étape 5, image 2 de 3 Lenovo IdeaPad N580 Keyboard and Trackpad Replacement, Keyboard and Trackpad: étape 5, image 3 de 3
    • Rotate the laptop so that now the hinge is facing away from you.
    • Remove the two 2.5 x 4.0 mm Phillips #0 screws from the underside of the laptop.
    • Slide the bottom panel towards you until it stops, and then carefully lift it off.
  6. Lenovo IdeaPad N580 Keyboard and Trackpad Replacement: étape 6, image 1 de 1
    • Remove the three 2.0 x 6.0 mm Phillips #0 screws located on the underside of the device.
  7. Lenovo IdeaPad N580 Keyboard and Trackpad Replacement: étape 7, image 1 de 3 Lenovo IdeaPad N580 Keyboard and Trackpad Replacement: étape 7, image 2 de 3 Lenovo IdeaPad N580 Keyboard and Trackpad Replacement: étape 7, image 3 de 3
    • Turn the laptop right side up and open the lid.
    • Using the spudger and your fingers, get in between the keyboard's edge and lift it up.
    • Carefully lift the keyboard ribbon cable out of the socket it is in.
  8. Lenovo IdeaPad N580 Keyboard and Trackpad Replacement: étape 8, image 1 de 2 Lenovo IdeaPad N580 Keyboard and Trackpad Replacement: étape 8, image 2 de 2
    • Remove the 2.5 x 6.0 mm Phillips #0 from the center of the device.
    • Close the laptop and place it face down once again.
  9. Lenovo IdeaPad N580 Keyboard and Trackpad Replacement: étape 9, image 1 de 1
    • If a hard disk drive is installed, remove the two 2.5 x 4.0 mm Phillips #0 screws.
    • Slide the hard disk drive out of its socket.
  10. Lenovo IdeaPad N580 Keyboard and Trackpad Replacement: étape 10, image 1 de 1
    • Remove the eleven 2.5 x 6.0 mm Phillips #0 screws.
    • Remove the three 2.0 x 3.0 mm flat head screws.
    • Remove the 2.5 x 4.0 mm Phillips #0 screw.
  11. Lenovo IdeaPad N580 Keyboard and Trackpad Replacement: étape 11, image 1 de 2 Lenovo IdeaPad N580 Keyboard and Trackpad Replacement: étape 11, image 2 de 2
    • Disconnect the two ribbon cables from the center.
    • Lift the keyboard bezel (with trackpad) straight up and out.
Alex Amorim
Membre depuis le 03/19/18
907 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G2, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S5-G2, Peak Spring 2018
UMASSD-PEAK-S18S5G2
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 477
