Aller au contenu principal
Lenovo IdeaPad P400 Touch RAM Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad P400 Touch RAM Replacement, Keyboard: étape 1, image 1 de 2 Lenovo IdeaPad P400 Touch RAM Replacement, Keyboard: étape 1, image 2 de 2
    • Remove the two 14mm Phillips #1 screws that attach the keyboard to the underside of the laptop.
    • Use a Phillips #1 screwdriver.
  2. Lenovo IdeaPad P400 Touch RAM Replacement: étape 2, image 1 de 2 Lenovo IdeaPad P400 Touch RAM Replacement: étape 2, image 2 de 2
    • Flip the laptop over and open it as you would to use it.
  3. Lenovo IdeaPad P400 Touch RAM Replacement: étape 3, image 1 de 2 Lenovo IdeaPad P400 Touch RAM Replacement: étape 3, image 2 de 2
    • Using your hands, lift the top corner of the keyboard, and keep lifting until the keyboard pops out. You will hear clicks as you do this.
    • If necessary, use the plastic spudger to pry up the corner and then lift the keyboard out with your hands.
    • Do not lift the keyboard out entirely. It will still be connected to the laptop. Only lift it enough so that it is unseated as shown in the second picture.
  4. Lenovo IdeaPad P400 Touch RAM Replacement: étape 4, image 1 de 3 Lenovo IdeaPad P400 Touch RAM Replacement: étape 4, image 2 de 3 Lenovo IdeaPad P400 Touch RAM Replacement: étape 4, image 3 de 3
    • Lift the top of the keyboard and flip the keyboard face down so that you can access the connectors underneath it.
    • Using your fingers, unplug the large connector that connects the keyboard to the center of the laptop by sliding the end of the strip out of the socket.
    • You may need to flip the white plastic bar up with a fingernail to be able to remove the strip.
  5. Lenovo IdeaPad P400 Touch RAM Replacement: étape 5, image 1 de 3 Lenovo IdeaPad P400 Touch RAM Replacement: étape 5, image 2 de 3 Lenovo IdeaPad P400 Touch RAM Replacement: étape 5, image 3 de 3
    • Using your fingers, unplug the second, smaller connector, located at the lower left hand side of the keyboard by sliding the strip out of the socket.
    • You may need to flip the white plastic bar up with your fingernail to remove the connector.
  6. Lenovo IdeaPad P400 Touch RAM Replacement, Battery: étape 6, image 1 de 1
    • Flip the laptop so that the bottom faces up.
    • You will first need to remove three 7mm Phillips #1 screws from the bottom of the laptop.
  7. Lenovo IdeaPad P400 Touch RAM Replacement: étape 7, image 1 de 3 Lenovo IdeaPad P400 Touch RAM Replacement: étape 7, image 2 de 3 Lenovo IdeaPad P400 Touch RAM Replacement: étape 7, image 3 de 3
    • Using a spudger, remove the back two feet of the laptop.
    • You may need to use a metal spudger if you cannot remove them with a plastic one.
  8. Lenovo IdeaPad P400 Touch RAM Replacement: étape 8, image 1 de 2 Lenovo IdeaPad P400 Touch RAM Replacement: étape 8, image 2 de 2
    • Remove the 7mm Phillips #1 screw beneath where the foot was. Do this for both sides.
  9. Lenovo IdeaPad P400 Touch RAM Replacement: étape 9, image 1 de 3 Lenovo IdeaPad P400 Touch RAM Replacement: étape 9, image 2 de 3 Lenovo IdeaPad P400 Touch RAM Replacement: étape 9, image 3 de 3
    • Flip the laptop over and open it.
    • Remove the 3mm Phillips #1 screw holding the disc drive in place.
    • Remove the disc drive by sliding it out.
  10. Lenovo IdeaPad P400 Touch RAM Replacement: étape 10, image 1 de 1
    • Remove four 7mm Phillips #1 interior screws.
  11. Lenovo IdeaPad P400 Touch RAM Replacement: étape 11, image 1 de 2 Lenovo IdeaPad P400 Touch RAM Replacement: étape 11, image 2 de 2
    • Close the laptop lid and flip it over.
    • Remove three 3mm Phillips #1 screws from beneath where the disc drive was located.
  12. Lenovo IdeaPad P400 Touch RAM Replacement: étape 12, image 1 de 3 Lenovo IdeaPad P400 Touch RAM Replacement: étape 12, image 2 de 3 Lenovo IdeaPad P400 Touch RAM Replacement: étape 12, image 3 de 3
    • Using a plastic spudger, pry open the laptop case starting near the disc drive.
    • Continue prying open the case by using the spudger to open it in new areas.
    • Once there is enough space to allow you to grip the case, use your hands to finish removing it.
    • It may be difficult at first. If the plastic spudger does not work, you can try using a metal one. Using a hand to pull the case open while prying may help as well.
  13. Lenovo IdeaPad P400 Touch RAM Replacement: étape 13, image 1 de 3 Lenovo IdeaPad P400 Touch RAM Replacement: étape 13, image 2 de 3 Lenovo IdeaPad P400 Touch RAM Replacement: étape 13, image 3 de 3
    • Using your fingers, unplug the battery from the laptop by taking the plug out of its socket.
  14. Lenovo IdeaPad P400 Touch RAM Replacement: étape 14, image 1 de 3 Lenovo IdeaPad P400 Touch RAM Replacement: étape 14, image 2 de 3 Lenovo IdeaPad P400 Touch RAM Replacement: étape 14, image 3 de 3
    • Unscrew the battery from the laptop by removing two 3mm Phillips #1 screws.
  15. Lenovo IdeaPad P400 Touch RAM Replacement: étape 15, image 1 de 2 Lenovo IdeaPad P400 Touch RAM Replacement: étape 15, image 2 de 2
    • Using your hand, remove the battery from the laptop by lifting one side and then pulling it out of its slot.
  16. Lenovo IdeaPad P400 Touch RAM Replacement, RAM: étape 16, image 1 de 2 Lenovo IdeaPad P400 Touch RAM Replacement, RAM: étape 16, image 2 de 2
    • Pull outward on both clips on the sides of the top RAM to release it.
    • The RAM will pop up slightly if you have pulled the clips out properly.
  17. Lenovo IdeaPad P400 Touch RAM Replacement: étape 17, image 1 de 1
    • Remove the top RAM from its slot by sliding it out.
  18. Lenovo IdeaPad P400 Touch RAM Replacement: étape 18, image 1 de 2 Lenovo IdeaPad P400 Touch RAM Replacement: étape 18, image 2 de 2
    • Pull outward on both clips on the sides of the bottom RAM to release it.
  19. Lenovo IdeaPad P400 Touch RAM Replacement: étape 19, image 1 de 1
    • Remove the bottom RAM from its slot by sliding it out.
Stephanie Botica
Membre depuis le 10/30/17
841 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 722
