Aller au contenu principal
Lenovo IdeaPad S340-15IWL Battery Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad S340-15IWL Battery Replacement, Back Panel: étape 1, image 1 de 2 Lenovo IdeaPad S340-15IWL Battery Replacement, Back Panel: étape 1, image 2 de 2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Battery Replacement: étape 2, image 1 de 1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Battery Replacement, Battery: étape 3, image 1 de 2 Lenovo IdeaPad S340-15IWL Battery Replacement, Battery: étape 3, image 2 de 2
    • Disconnect the battery cable by gently pulling it straight out of the connector.
    • Be sure to pull parallel to the device to avoid bending the motherboard connector.
    • The battery connector does not lock and only requires light pressure to insert and remove.
    • Remove the battery from the laptop.
2 autres ont terminé cette réparation.
Luke Ruff
Membre depuis le 09/17/21
183 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
Worked wonderfully. Thanks for the great instructions.
Deb Dhar - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 20
30 derniers jours : 142
Total : 5,376
