Introduction
Use this guide to replace the digital board.
Look at the back of the tablet and locate the speakers on top of the rear cover.
  • Look at the back of the tablet and locate the speakers on top of the rear cover.
  • There is a smaller plastic cover that runs across the top of the device.
  • Wedge the blue opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
Ajouter un commentaire
Remove the following two screws: M3.0 x 3.0 mm #00 phillips screws (black)
  • Remove the following two screws:
    • M3.0 x 3.0 mm #00 phillips screws (black)
Once it is unscrewed, remove the rear cover This may take a little force to get off but with enough force it should pop right off Use a blue opening tool to pry it open
  • Once it is unscrewed, remove the rear cover
    • This may take a little force to get off but with enough force it should pop right off
  • Use a blue opening tool to pry it open
    • Slide the tool to one corner then grab another tool and slide it to the opposite corner
  • Pull the cover up and it will come off
Use the tweezer tool to flip up the three small plastic locks attached to the digital board. Then, slide newly exposed ribbons out.
  • Use the tweezer tool to flip up the three small plastic locks attached to the digital board.
  • Then, slide newly exposed ribbons out.
Remove the following two screws: M5.3 x 1.75 mm #00 phillips screws (silver)
    • M5.3 x 1.75 mm #00 phillips screws (silver)
Once it is unscrewed, use the tweezer tool to pull the digital board straight out.
  • Once it is unscrewed, use the tweezer tool to pull the digital board straight out.
4 autre(s) ont terminé cette réparation.
Brian
Membre depuis le 22/04/2014
559 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-19, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 2,620
