Aller au contenu principal
Lenovo Ideapad 110S-11IBR Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Ideapad 110S-11IBR Battery Replacement, Battery: étape 1, image 1 de 1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Battery Replacement: étape 2, image 1 de 2 Lenovo Ideapad 110S-11IBR Battery Replacement: étape 2, image 2 de 2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Battery Replacement: étape 3, image 1 de 2 Lenovo Ideapad 110S-11IBR Battery Replacement: étape 3, image 2 de 2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Battery Replacement: étape 4, image 1 de 1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Battery Replacement: étape 5, image 1 de 2 Lenovo Ideapad 110S-11IBR Battery Replacement: étape 5, image 2 de 2
    • Lift the battery up and out of the device.
8 autres ont terminé cette réparation.
Alex Daughters
Membre depuis le 09/20/17
405 Réputation
2 tutoriels rédigés
Équipe
Un commentaire
Great instructions but where can you by a replacement battery? I can’t find one anywhere.
Mark Thompson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 43
Total : 7,865
