Aller au contenu principal
Lenovo Ideapad Yoga 2 11 Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Ideapad Yoga 2 11 Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Begin by turning your closed laptop so that you are looking at the bottom panel.
  2. Lenovo Ideapad Yoga 2 11 Battery Replacement: étape 2, image 1 de 2 Lenovo Ideapad Yoga 2 11 Battery Replacement: étape 2, image 2 de 2
    • Locate the 10 screws (6mm) around the border of the panel.
    • Using the Torx T5 Screwdriver, remove the screws.
  3. Lenovo Ideapad Yoga 2 11 Battery Replacement: étape 3, image 1 de 1
    • Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
  4. Lenovo Ideapad Yoga 2 11 Battery Replacement, Battery: étape 4, image 1 de 2 Lenovo Ideapad Yoga 2 11 Battery Replacement, Battery: étape 4, image 2 de 2
    • Locate the battery in the bottom right corner.
    • Using a Phillips #000, remove the 6 screws (3.5mm) on the border of the battery and the 7th screw (6.5mm) that is in the center of the battery.
  5. Lenovo Ideapad Yoga 2 11 Battery Replacement: étape 5, image 1 de 3 Lenovo Ideapad Yoga 2 11 Battery Replacement: étape 5, image 2 de 3 Lenovo Ideapad Yoga 2 11 Battery Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Locate the cable connecting to the battery. It is located at the top-center of the battery.
    • Use a pair of tweezers and place it so that the tweezer is around the cables. Gently pull the cables towards the battery to disconnect the cable.
  6. Lenovo Ideapad Yoga 2 11 Battery Replacement: étape 6, image 1 de 2 Lenovo Ideapad Yoga 2 11 Battery Replacement: étape 6, image 2 de 2
    • There may be tape around the edge of the battery to secure some wires. Use a pair of tweezers to remove the tape so that the wires are no longer attached to the battery.
  7. Lenovo Ideapad Yoga 2 11 Battery Replacement: étape 7, image 1 de 2 Lenovo Ideapad Yoga 2 11 Battery Replacement: étape 7, image 2 de 2
    • After you have unscrewed the screws, unplugged the cable, and removed the tape and wires, you can remove the battery from your laptop.
2 autres ont terminé cette réparation.
Andria Chen
Membre depuis le 10/17/17
624 Réputation
5 tutoriels rédigés
Équipe
UC Santa Barbara, Team S1-G5, Weedon Fall 2017 Membre de l'équipe UC Santa Barbara, Team S1-G5, Weedon Fall 2017
UCSB-WEEDON-F17S1G5
5 membres
5 tutoriels rédigés
Un commentaire
Excellent instructions makes it easy even for novice
bhimanagouda patil - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 1,815
