Aller au contenu principal
Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement
Ce dont vous avez besoin
  1. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: étape 1, image 1 de 3 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: étape 1, image 2 de 3 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: étape 1, image 3 de 3
    • Carefully remove the broken key(s). Use the flat end of the spudger to gently pop the key off.
    • When removing the key(s) be very cautious not to remove the white plastic pieces underneath with it.
    • When reinstalling key, no spudger is needed. Just pop it into place with fingers.
  2. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: étape 2, image 1 de 2 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using the flat end of the spudger, very carefully lift up the corners of the white plastic piece. Do not disconnect the two.
    • With the help of tweezers (needle nose works best), pull the connected plastic pieces out.
    • If the two plastic pieces come apart refer to the last picture, showing the orientation in which they should be connected.
    • For reinstallation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
Kaylea
Membre depuis le 10/04/18
185 Réputation
1 tutoriel rédigé
Équipe
3 commentaires
This is only for the key caps, what about the keyboard itself?
Rick Montoya - Réponse
I agree the video is mislabeled. You are not replacing the board just keys.
Pat Schutte - Réponse
Please create a tutorial for keys with stabilizer like space bar and enter keys.
Affix - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 31
30 derniers jours : 176
Total : 10,139
