Introduction
This will show you how to remove the keyboard on the Lenovo N23 Yoga Chromebook
Flip the computer over. Remove the 9 screws surrounding the edges of the computer. Remove the single screw near the center of the computer.
  • Flip the computer over.
  • Remove the 9 screws surrounding the edges of the computer.
  • Remove the single screw near the center of the computer.
Ajouter un commentaire
Use a smaller plastic panel popping tool to begin (if you have one). You may increase to a larger size as you go (if you have one)
  • Use a smaller plastic panel popping tool to begin (if you have one). You may increase to a larger size as you go (if you have one)
  • Slowly work your way around the edges of the computer.
  • Closer to the screen the clips will be sturdier, use a little more force but still be cautious.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
On the main board, lift up on the black tabs of the connectors that are connected to the ribbons.
  • On the main board, lift up on the black tabs of the connectors that are connected to the ribbons.
  • Remove the ribbon connectors gently from the main board.
The keyboard should be free and disconnected from the rest of the computer.
  • The keyboard should be free and disconnected from the rest of the computer.
2 autre(s) ont terminé cette réparation.
Drew Canada
Membre depuis le 03/04/2018
424 Réputation
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 15
Total : 41
