Introduction
This repair guide will help to remove the backplate of the Lenovo Thinkpad Edge E520 which is essential to repair the inner components of the laptop.
Flip over the laptop and position it with the battery being furthest away from you. Remove the four screws on the edges of the T-Shaped plate. Remove the T-Shaped plate from the back of the computer.  It should come off easily if all four aforementioned screws are removed.
  • Flip over the laptop and position it with the battery being furthest away from you.
  • Remove the four screws on the edges of the T-Shaped plate.
  • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
  • Screw length 6.35 mm, head 3.175 mm
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
David Skarbek
Membre depuis le 01/03/2018
229 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G2, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S1-G2, Simcock Spring 2018
UMASSD-SIMCOCK-S18S1G2
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 27
