Introduction
This guide will help to replace the CD disk drive from the Lenovo Thinkpad Edge E520 CD Disk Drive.
Pièces
Aucune pièce nécessaire.
Power off computer before the start of these steps.
  • Power off computer before the start of these steps.
  • Close the computer screen.
Ajouter un commentaire
Flip the computer so that the back is facing upwards. The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
  • Flip the computer so that the back is facing upwards.
  • The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
Slide the switch towards the unlocked lock icon. While holding it in the unlocked position, slide the battery towards the hinge.
  • Slide the switch towards the unlocked lock icon.
  • While holding it in the unlocked position, slide the battery towards the hinge.
  • Fully separate the battery pack from the back of the laptop.
Flip over the laptop and position it with the battery being furthest away from you. Remove the four screws on the edges of the T-Shaped plate. Remove the T-Shaped plate from the back of the computer.  It should come off easily if all four aforementioned screws are removed.
  • Flip over the laptop and position it with the battery being furthest away from you.
  • Remove the four screws on the edges of the T-Shaped plate.
  • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
  • Screw length 6.35 mm, head 3.175 mm
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
There are two screws that have keyboard symbols pointing at them.
  • There are two screws that have keyboard symbols pointing at them.
  • Unscrew the screws with a 3.175 mm diameter and 6.35 mm length with a Phillips head screwdriver.
Turn the laptop back over so that the keyboard is facing you. Use your hands to separate the keyboard from the laptop Use your hands to separate the keyboard from the laptop
  • Turn the laptop back over so that the keyboard is facing you.
  • Use your hands to separate the keyboard from the laptop
Remove all remaining screws on the back of the device.
  • Remove all remaining screws on the back of the device.
  • Screw length 6.35 mm, head 3.175 mm Screws behind battery length 3.175 mm, head 3.175 mm
Flip device back over and open the screen. Insert the prying tool on one edge of the case and follow along all four edges until the case frees up. Remove the case.
  • Flip device back over and open the screen.
  • Insert the prying tool on one edge of the case and follow along all four edges until the case frees up.
  • Remove the case.
The silver block contains two screws. Unscrew the two screws to remove the clamp that holds the disk drive in place.
  • The silver block contains two screws.
  • Unscrew the two screws to remove the clamp that holds the disk drive in place.
  • Remove the screws holding the disk drive in place and then slide outwards to remove
Andrew Martin
Membre depuis le 01/03/2018
184 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G2, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S1-G2, Simcock Spring 2018
UMASSD-SIMCOCK-S18S1G2
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 25
