Aller au contenu principal
Lenovo ThinkPad P52 Keyboard Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad P52 Keyboard Replacement, Remove track pad click covers: étape 1, image 1 de 1
    • The first step is to remove the track pad left and right click covers. I used a plastic spudger tool to carefully pry and remove.
  2. Lenovo ThinkPad P52 Keyboard Replacement, Loosen screws holding keyboard in: étape 2, image 1 de 1
    • Once you have removed the covers you will see two screws (one on each cover). Using a PH0 screw driver, loosen the screws (they are attached so will not come out).
  3. Lenovo ThinkPad P52 Keyboard Replacement, Remove keyboard: étape 3, image 1 de 2 Lenovo ThinkPad P52 Keyboard Replacement, Remove keyboard: étape 3, image 2 de 2
    • Once the screws are loose, you can push the keyboard up to release the tabs holding it on on the bottom. I use a spudger to assist with this.
    • Once the tabs are released, you can carefully pull the keyboard down and flip it towards you. Exposing the two cables connecting it to the motherboard.
  4. Lenovo ThinkPad P52 Keyboard Replacement, Unplug ribbon cable: étape 4, image 1 de 1
    • Using a plastic spudger, release the clips holding the cable ribbons on.
    • Remove cable ribbons and keyboard has now been removed.
  5. Lenovo ThinkPad P52 Keyboard Replacement, Insert new Keyboard: étape 5, image 1 de 3 Lenovo ThinkPad P52 Keyboard Replacement, Insert new Keyboard: étape 5, image 2 de 3 Lenovo ThinkPad P52 Keyboard Replacement, Insert new Keyboard: étape 5, image 3 de 3
    • The new keyboard can be attached by running these steps in reverse.
    • First attach ribbon cable
    • The fold keyboard into laptop starting at top and then clip in towards bottom by pulling it down.
    • Then tighten the screws under the left and right click covers
    • Then attach the covers
Bill
Membre depuis le 09/17/14
818 Réputation
5 tutoriels rédigés
2 commentaires
This isn’t for the P52s….
James Liu - Réponse
Thank you. It is for the P52 model. I don’t know if the P52s is the same as the P52 as far as replacing the keyboard but when I was making the article it auto-populated the P52s and I didn’t change it back. I have made the appropriate change.
Bill -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 20
30 derniers jours : 106
Total : 5,807
