Aller au contenu principal
Lenovo ThinkPad T431S Charging Port Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: étape 1, image 1 de 2 Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: étape 1, image 2 de 2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Charging Port Replacement: étape 2, image 1 de 2 Lenovo ThinkPad T431S Charging Port Replacement: étape 2, image 2 de 2
    • Unscrew the single, 3.0 mm screw with a Phillips #1 screwdriver bit that holds the charging port housing into place.
  3. Lenovo ThinkPad T431S Charging Port Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T431S Charging Port Replacement: étape 3, image 2 de 2
    • Remove the small, white connector cable by prying it from the connector with a plastic opening tool.
    • Remove the charging port assembly.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 31
Total : 3,988
