Aller au contenu principal
Lenovo ThinkPad T495 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Baseplate: étape 1, image 1 de 1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Wi-Fi Card Replacement: étape 2, image 1 de 1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: étape 3, image 1 de 3 Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: étape 3, image 2 de 3 Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to lift the two coaxial cable connectors vertically, disconnecting them from the Wi-Fi card.
    • Use a Phillips #00 screwdriver to remove the 6 mm screw, causing the Wi-Fi card to pop up.
  4. Lenovo ThinkPad T495 Wi-Fi Card Replacement: étape 4, image 1 de 2 Lenovo ThinkPad T495 Wi-Fi Card Replacement: étape 4, image 2 de 2
    • Grip the Wi-Fi card between your fingers and pull it in the direction of the card, at a slight angle, until it releases from its port.
Christian Taylor
Membre depuis le 03/28/22
523 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-6, Petersen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 1-6, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G6
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 27
Total : 779
