Aller au contenu principal
Lenovo ThinkPad W540 Display Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad W540 Display Replacement, Display: étape 1, image 1 de 2 Lenovo ThinkPad W540 Display Replacement, Display: étape 1, image 2 de 2
    • Open your laptop so that the screen is at around a 180 degree angle.
    • Using a plastic opening tool, pry open the outer frame of the display.
    • Generally, it is best practice to start from the corner first, and then guide the opening tool around the the frame.
  2. Lenovo ThinkPad W540 Display Replacement: étape 2, image 1 de 2 Lenovo ThinkPad W540 Display Replacement: étape 2, image 2 de 2
    • Use a Phillips #00 screwdriver to unscrew the four 3 mm screws holding the display, one for each corner.
    • Once unscrewed, flip the display over the other side of the laptop (keyboard end).
  3. Lenovo ThinkPad W540 Display Replacement: étape 3, image 1 de 2 Lenovo ThinkPad W540 Display Replacement: étape 3, image 2 de 2
    • Use a plastic spudger, safety lift the adhesive tape from the connector.
    • Do not disregard the tape from the connector entirely as you will be reusing it later.
    • This adhesive tape will be strong, remove the tape carefully to prevent damage to the display connector.
  4. Lenovo ThinkPad W540 Display Replacement: étape 4, image 1 de 1
    • Safely disconnect the display from the connector.
    • Although you can use your hands to disconnect the connector, it is recommended that you use a spudger instead.
Kevin Dang
Membre depuis le 10/30/23
333 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-2, Konn Fall 2023 Membre de l'équipe UMass Dartmouth, Team 3-2, Konn Fall 2023
UMASSD-KONN-F23S3G2
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 16
Total : 88
