Aller au contenu principal
Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): étape 1, image 1 de 2 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): étape 1, image 2 de 2
    • Turn your laptop over so the backplate is facing you.
    • Start with your Phillips #0 screwdriver and unscrew the 2 screws in each of the top corners of the backplate.
    • These screws should stay put on the backplate, and should not fall off.
  2. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: étape 2, image 1 de 2 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: étape 2, image 2 de 2
    • With your Phillips #00 screwdriver, simply remove the one 3mm screw on the upper left side.
  3. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: étape 3, image 1 de 3 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: étape 3, image 2 de 3 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: étape 3, image 3 de 3
    • Remove the ODD by using a plastic opening tool to push the drive out of the side of the laptop.
    • Make sure to place the tool where we removed the screw holding the drive in place in Step 2.
  4. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: étape 4, image 1 de 1
    • Once the ODD has popped out, simply grab and pull out the drive bay.
Isaac
Membre depuis le 10/30/23
109 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 Membre de l'équipe UMass Dartmouth, Team 4-1, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G1
4 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 12
Total : 74
