Aller au contenu principal
Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Back Cover: étape 1, image 1 de 1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: étape 2, image 1 de 1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: étape 3, image 1 de 1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: étape 4, image 1 de 2 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: étape 4, image 2 de 2
    • Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: étape 5, image 1 de 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: étape 5, image 2 de 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: étape 5, image 3 de 3
    • Remove the battery using your hand or a prying tool.
  6. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: étape 6, image 1 de 2 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: étape 6, image 2 de 2
    • Use the Phillips #1 screwdriver to remove the two 1.2 mm screws.
  7. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: étape 7, image 1 de 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: étape 7, image 2 de 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: étape 7, image 3 de 3
    • Unplug the speaker cable from the board.
  8. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: étape 8, image 1 de 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: étape 8, image 2 de 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: étape 8, image 3 de 3
    • Lift up the marked latch and remove the cable.
    • Remove the speaker.
You will have the speaker replaced and fully working. To reassemble your device, follow these instructions in reverse order.
Diego Garcia reyes
Membre depuis le 09/01/21
493 Réputation
5 tutoriels rédigés
Équipe
Gateway, Team 1-3, Saknee Fall 2021 Membre de l'équipe Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 39
Total : 800
