Aller au contenu principal
Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Back Cover: étape 1, image 1 de 2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Back Cover: étape 1, image 2 de 2
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: étape 2, image 2 de 2
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Battery: étape 3, image 1 de 2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Battery: étape 3, image 2 de 2
    • Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
  4. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: étape 4, image 1 de 1
    • Take out the battery by lifting it from the bottom edge of the laptop, and then pulling away from the motherboard.
  5. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Fingerprint Scanner: étape 5, image 1 de 2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Fingerprint Scanner: étape 5, image 2 de 2
    • Use the Phillips #0 screwdriver to remove the 2mm screw that secures the cover of the fingerprint scanner.
  6. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: étape 6, image 1 de 1
    • Remove the cover by grabbing it and gently pulling up and to the left.
  7. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: étape 7, image 1 de 2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: étape 7, image 2 de 2
    • Use a nylon spudger to lift up the black bar that secures the cable.
    • Disconnect the ribbon cable from the fingerprint scanner by pulling the cable directly out.
  8. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Touchpad: étape 8, image 1 de 2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Touchpad: étape 8, image 2 de 2
    • Use a spudger to peel back the black adhesive pad.
    • Be gentle; the black adhesive pad is delicate and may rip.
  9. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: étape 9, image 1 de 2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: étape 9, image 2 de 2
    • Lift the lever that secures the cable.
    • Pull the cable out to disconnect the ribbon cable that connects to the touchpad.
    • This is the same procedure for removing most of the ribbon cables.
  10. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: étape 10, image 1 de 2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: étape 10, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the four 1mm screws that secure the touchpad to the laptop.
  11. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: étape 11, image 1 de 2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: étape 11, image 2 de 2
    • Once the screws are removed, the touchpad can be removed.
    • The touchpad may even fall out once the screws are removed. Be sure to secure the touchpad before it falls out.
Michael Megna
Membre depuis le 01/23/20
1 277 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S19-G4, White Winter 2020 Membre de l'équipe Cal Poly, Team S19-G4, White Winter 2020
CPSU-WHITE-W20S19G4
3 membres
22 tutoriels rédigés
Un commentaire
Where do I get a new mouse pad after I have taken it off?
Jeremiah Gregg - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 140
Total : 4,215
