Aller au contenu principal
Lenovo ThinkPad X1 Yoga (6th Gen) Fan Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Base Panel: étape 1, image 1 de 3 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Base Panel: étape 1, image 2 de 3 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Base Panel: étape 1, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the five 5.0 mm screws from the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Fan: étape 2, image 1 de 2 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Fan: étape 2, image 2 de 2
    • Use a Phillips #000 screwdriver to loosen the four 5 mm captive screws.
    • The captive screws will stay attached to the fan as you remove it.
  3. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement: étape 3, image 1 de 3 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement: étape 3, image 2 de 3 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement: étape 3, image 3 de 3
    • Place the pointed tip of a spudger behind the small plastic tab on either side, and "walk" the fan's connector out of its port, alternating between tabs, until the plug disconnects.
    • Lift the fan up and out.
Taylor Morgan
Membre depuis le 02/15/22
521 Réputation
5 tutoriels rédigés
Équipe
Un commentaire
Hi, Do you know what is the fan part number? Where did you get the fan from?
hamedabedi - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 36
Total : 581
