Aller au contenu principal
Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Back Cover: étape 1, image 1 de 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: étape 2, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: étape 3, image 1 de 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Fan: étape 4, image 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Fan: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Lift up the small, metal tab using a spudger.
    • Do not use the metal spudger unless if it's being used for serious prying power. The metal spudger may damage or puncture internal components in the device if too much pressure is applied.
    • Gently lift the ribbon cable from its socket using nylon-tipped reverse tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: étape 5, image 1 de 1
    • Using the Phillips #0 screwdriver, unscrew the four 4 mm screws directly next to the fan.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: étape 6, image 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: étape 6, image 2 de 2
    • Loosen the four 5 mm screws in the metal extension attached to the fan.
    • The screws do not need to be completely removed from the fan.
    • Remove the fan using your fingers.
Alex Shacoski
Membre depuis le 02/10/20
270 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S22-G3, Regan Winter 2020 Membre de l'équipe Cal Poly, Team S22-G3, Regan Winter 2020
CPSU-REGAN-W20S22G3
5 membres
7 tutoriels rédigés
3 commentaires
When you remove a heasink (or heat transfer pipe) from a chip, shouldn't you re-apply any thermal paste? Surely it had some?
Edward Dekkers - Réponse
after pressing power button Cooling fan runs for 2 sec then it stays off . What is the problem ?
Tonmoy Arafin - Réponse
Is there any upgrade that one can do to the fan or pipe except new thermal paste? I find it quite loud and inefficient. Isn't there a third-party one which is quieter?
Oliver - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 30
Total : 940
