Introduction
This guide is for removing the ThinkPad X100e's LCD display and replacing it with a new one.
  • Use a Spudger tool to remove the screw covers on each side of the screen.
  • Be sure not to lose screw covers.
Ajouter un commentaire
Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
  • Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
Pry open the bezel carefully with the spudger tool.
  • Pry open the bezel carefully with the spudger tool.
  • You will want to do this until the frame is completely off.
Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
  • Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
  • Be sure to set the screws aside on the magnetic mat.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
  • Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
  • The other two screws are located in the exact place on the other side.
  • Don't forget to place the screws on the magnetic mat, separate from other screws.
Remove the connector located at the very top of the screen beside the webcam. To remove the connector, simply pull the connector out.
  • Remove the connector located at the very top of the screen beside the webcam.
  • To remove the connector, simply pull the connector out.
Fold the panel over until a strip of black tape is visible.
  • Fold the panel over until a strip of black tape is visible.
  • Peel the tape down until you get to the base.
Peel the piece of transparent tape back. At this point there should be some exposed wires underneath the tape.
  • Peel the piece of transparent tape back.
  • At this point there should be some exposed wires underneath the tape.
Remove the connector carefully with the spudger tool.
  • Remove the connector carefully with the spudger tool.
Remove the black tape fully.
  • Remove the black tape fully.
  • Now your device is ready for a new panel.
Jose Orlando Guerra
Membre depuis le 08/02/2018
427 Réputation
2 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 25
Total : 93
